Help for Eplan
Eplan 5.40 i can use the graphic outputs frame (.frm) which are default but i am not able to edit it or create a new one
I have a dutch version, so I will try to help you.
Main Menu
Artical (3th from the left)
Positionlist (last option)
this should open a new menu:
Generate
Graphical (1st option)
Bill of materials
If you changed something in your drawing you should mark the option 'read schematics again'.
Thanks for ur reply, but i m facing the problem for making custom sheet for Bill of materials like we make forms for our drawings. So i want to create my own Bill of Materials sheet & use it for my projects.
Parag
There is one more problem i m facing here in Eplan is that, during the numbering, every wire is marked with ? sign no numbers are displayed. help me on this also if possible
Parag
Parag
Main Menu-Project-numbering-wiring(?)
wiringnumbering-wiring(connections?)-make-?-insert
this should give you the questionmarks ?
Then
wiring(connections?) - numbering
I never made my own sheet for the bill of materials but I have a manual. I will look into it tomorrow. I should give the next feedback in 24 hours.
But to make sure: you know how to generate a bill of materials but you want to make a new layout for this kind of page?
I've just looked for the manual; I've one in dutch and one in german, so I think this will not be of any use for you.
Regarding your question of making your own layout. Sorry, I don't have an example to work with. What I do know is this:
In Project-managment you can choose a TAB named 'project-type'. In the first row 'projecttype' you can choose '2 = form (?)-project'.
That should be the first stap of making a new form-page.There my knowledge stops.
On a german website a found this info:
for the data you need to use these numbers:
601 Betriebsmittelkennzeichen -->firm-lettercode????
634 amount
602 Artikelnumber
608
Firm of material
http://ww3.cad.de/cgi-bin/ubb/forum...number=150&DaysPrune=1000&LastLogin=&mystyle=
ok no problem!!!!!! I will try & let u know abt dat if i find out, can u tell me the URL frm whr i can downliad English manual
Praichura,
I tried a project (copy) where I already had an old bill of materials and changed the projecttype to 'Form project'.
I opened the project and clicked on the insertpoints of a bill of materials. I could look at and change the type of the element e.g. 645-total price. You can also see all the type of element what you can use in a bill of material.
Then you should try 'edit' (4th menu from the right) and choose 'create macro/form' -> 'Form'.
Like this you should also be able to create your own page-layout.
regards,
Ivo
Thanks for ur support
but the file format that it is saving is *.sko but i need to store it as *.frm format it is not saving in that format
Parag
Dear All, How can I make numbering for connections (wires) in EPlan Electric? Thank you
19
8,156
I am learning to use this software, i was using Eplan 5.4 before. In this i m finding the problem that whenever i try to move the object it is...
2,148
Im using EPLAN electric P8 v. 1.7. I'm trying to move a project from my labtop to my desktop. Ive tried the process: project>restore>project...
12,623
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
101
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
462
