Help! Keyence CV5000-controllogix ethernet/ip communication
vagler
Aug 2010
Hermosillo
Has anybody been able to control a CV5000 vision system using commands via ethernet/ip with explicit message instructions, or by any other mean using a controllogix controller.
I have tried everything indicated on the CV manual but it won't just work, I don't know what I am missing.
Any help will be appreciated.
I finally did it, is so much simpler than how is explain on the manual. For you who need this info here is how is configured:
Message type: CIP Generic
Service Type: Custom
Source Element: tag(indicated below)
Source Length: (see below)
Service Code: 4C (For sendig a comand)
Class: 64
Instance: 1
Attribute: 6E (For sending an array of bytes)
Destination: CV output tag (eg:Camera:O.Data)
Source element: a INT tag (not DINT as mentioned on the manual :S) where you place the command number and parameter.
For example if you want to switch programs is: 24, 1 for SD memory one and the program number:
My tag is: camera_cmd_tx filled like this:
camera_cmd_tx[0]=24
camera_cmd_tx[2]=1 (for SD memory number)
camera_cmd_tx[4]=1 (for program number)
Source length: Depends if you send only a command number is 4 bytes, if you send command number and parameters is 12.
Hope it helps!
Hi Team, I am having to convert a old KV unit & am trying to decipher some of the instructions/functions used, referencing the help menus of...
1,632
My company has several of the IV-Navigator vision cameras that we use for nut detection on an area that is very similar on the Gray scale. We have...
2,964
Hi, sombody with experience can help me ,with plc keyence kv 10r , what software need to program .???
1,649
Hello, I have a DL06 with a D0-Ecom100 card connected to a Keyence IL1000 Laser measurement device through a DL-EP1 ethernet comm module. Also...
4,398
my name is danish i am using keyence KV24r plc, i want to pick it's data serially to HMI through OPC i have try KEPserverEX matricon and INGEAR...
2,829
