Keyence IV-Navigator Help
sjanes9
Nov 2012
Lexington
52
My company has several of the IV-Navigator vision cameras that we use for nut detection on an area that is very similar on the Gray scale. We have a lot of trouble with accuracy and repeat-ability to find good and bad parts with these cameras. I really feel like they aren't adequate for our application. But I wanted some other opinions before I go through validating a different system to use as our standard. Does anyone have any thoughts on the best way to detect this reliably with the IV-Navigator cameras?
Is the lighting in the detection area good?
If the 'nut' to be detected is the same 'color' as the background . . .
I would try changing the background to something that is
much easier to differentiate from the 'nut'.
Poet.
Our lighting is not great. But a lot of our parts don't have a way to change the back lighting. As it's part on part. I have tried adding different lighting from the side. But my biggest issue is that the nut is never in the same position. Meaning, it is auto-fed onto the part and I can't control how the projections sit. It gets even harder since at times I have to judge more than one nut at a time.
I've been using the Series - IV with the advanced toolset lately. The cost is several hundred per unit but they do alot of same things as the next high-end systems do and easier to set up. Have you tried the inspection tool auto tuning function yet?
I have a .ain file that I need to load into two BL-781 barcode scanners. Apparently I need the 'AUTO ID Navigator' software, which according to...
7,132
48
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
83
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
96
Hello all I've got a cell with four Keyence IV3 cameras that are saving images to a FTP server, we are also labeling the parts with a time date...
268
