I have the CPU FA2J, the problem is sometimes the clock scan of 1 sec is extended to 5 sec, causing fault in the process, the plc have connect to scada Intouch.
Are you saying that the PLC total scan time changes from 1 sec to 5 sec ?
- even 1 sec seems quite long for an FA2J.
Or is it a PLC timer that is changing from 1 sec to 5 seconds ?
Are you seeing the 5 sec happen through your Intouch graphics?
Or are you watching it directly at the PLC (ie via an output)
- it may just be an Intouch scan-rate issue.
Try driving an output via M314 & watch the output LED - does it ever stay on or off for 5 sec ?
