Help Me Understand DL06 instruction
diat150
Mar 2006
Louisiana
1,474
Can someone explain to me what exactly the SP62 is doing. I understand that SP62 is a greater than instruction but dont really understand its purpose, at least here.
These old AD units really give me trouble, I much rather the click!
well, I think I answered my own question. It looks whatever rung has a ldr and a cmpr before that sp62 instruction is what gets compared. provided c200,c202,or c204 is enabled.
You have it correct. SP62 along with others in this range are the result bits for the 32 bit compares. While 16 bit compares can be performed inline on a rung the 32 bit compares are in an output box instruction. The result bits of one of these instructions must be utilized before another of the 32 bit compares is executed.
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
123
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,110
Okay. On a semi-impulse, I scored one of these units relatively inexpensively. A development rig upgrade over my L320ERM: 5MB user memory, 120...
1,453
OK, so am wanting to move 100+ tags into a new UDT. I figured the easiest way to do this is to copy and paste the tags into excel. Then...
1,938
I know what it is doing, it is creating P#DB104.DBX48.0 Byte 32. This is later used in an SFC14 block further on. I just can't wrap my head...
1,627
