Help! My window is stuck!
pstephens
Sep 2004
Indiana
342
What's going on here?!
I was working along in DirectSoft, when I suddenly noticed that the header of my program window was "trapped" under the DirectSoft menu header. I can't move it back down because the thing you click on to move it is hidden! How it got this way I have no idea.
Durn computers!
Here's what the screen looks like:
I've been trying all sorts of things to fix it. Am I missing something obvious? (Before anybody says it... yes, I should be doing something more fun than this on a saturday night!)
Paula
Paula,
It is scary, I know, to be trapped in a Window with no apparent exit!! It has happened to me just like that. However, just click, on Window, then Cascade, or Tile (anything to change the shape of the window so you can see the scroll bar again).
Another option...
It doesn't look too far out of reach, so go to the "View" menu and uncheck the "Toolbar" selection. That should allow you access to the top of the window. Drag it back down and re-check the "Toolbar" selection.
beerchug
-Eric
Re: Another option...
I tried that move, Eric. The window just moved up that much further.
Lancie1's advice did the trick, though. Thanks anyway.
Paula
hello to all genuis.. could any 1 help me..how could i work a plc which connect to window base..and run system thru computer basiclly i m good...
2,531
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
121
50
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
24
437
please help me . I have to make this ladder diagram and I can’t figure it out :(
359
