dave dempsey
OP
yes the atd are from the same internal relay (anti tie down)In your first rung are the coil instruction labeled "ATD Relay 1" and the contact instruction labeled "ATD" supposed to be from the same device?. In the same rung, is the contact labeled "All Reset" from the coil in the next rung? What is the source of the unlabeled contact?
the all reset is coming up at the end of the program for if the pushbuttons aren't held in until the clamp clamps then it goes back to initial conditions and resets the counter and timers
