Help on Devicnet for D-485 (GE make) converter
raul_vaze
Feb 2008
mumbai
87
I have some GE make energy meters communicating on Modbus as slaves to a GE make D-485 converter (Modbus-Devicenet converter).
Can anobody explain to me about how to read from the D-485 converter. I have really no idea about wat are instances , attributes , classes...
D-485 is set for correct node address and proper baud rate..Cabling too is correct
Thanks in Advance
Raul
Hi Raul,
I assume that you have the Enervista P485/D485 setup software, since you wrote: D-485 is set for correct node address and proper baud rate..Cabling too is correct.
In the software when highlighting Modbus Network and right-clicking, you can select Modbus Network Monitor to see the live data from/to your modbus slaves.
If the gateway is connected to a DeviceNet scanner, I would advise you to contact the DeviceNet scanner manufacturers support for how to read/write data to the gateway.
BR
Patrick Lansdorf
FAE
HMS Industrial Networks
Hi pudden ,
Thanks for the reply. In devicnet when u wanna read data from any device , if u are using explicit messaging then u need to have information about attributes , objects etc. I tried to look into the D-485 manual about the information but couldnt understand it properly. So can u pls tell me as to how to read from the gateway
20
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
127
please help me . I have to make this ladder diagram and I can’t figure it out :(
344
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
225
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
230
