Help Please
killuminati96
Dec 2005
Leicester
can sumone tell me which site i can find two PLC's. I need two PLC's.
one pick and place robot used to move filled bottles into crates and operate the conveyor to take them to the loading bay and the main PLC that controls the bottle filling ,capping lablelling system.
The main pick-and-place conveyor robot needs a simple PLC
INPUTS: 20 STANDERD 24V D.C DIGITAL INPUTS
OUTPUTS: 12 OPERATING MAINLY INDICATORS 24V D.C SOLENOID VALVES AND A COUPLE OF 24V D.C SOLID-STATE RELAYS
AUXILIARY: A PROFIBUS NETWORK INTERFACE TO RECEIVE CONTROL
SYSTEMS FROM THE MAIN PLC
SPEED: DOES NOT REQIRE ANY HIGH SPEED RESPONCE
The main PLC controlling the bulk of the bottling plant needs a more complex PLC
INPUTS: 120 standard 24v d.c inputs. Six 4-20mA anologue inputs.
OUTPUTS: 38 srtandard relay type outputs. Eight high speed transister outputs. Two 4-20mA anolouge outputs.
Auxiliary: A profibus netwrk interface to send control signals to the plc;s controlling the bottle wash plant and the pick-and-place robot.
speed: this will need to be high performance PLC,as it needs maximum responce time to of less then 25ms to fill a bottle.and the program length is likely to be around 2,500 instrutions
plese help me because i cant find the PLC with the specific reqirements anywhere
any help will be greatfull,thanks in advance
If you go to www.AutomationDirect.com you might be able to use a DL-06 (20 inputs & 16 outputs), and a DL-205, or DL-405. If you call them and ask for tech support, they will help you with choosing the proper components for the required configuration.
Doesn't that rule out AD?
Not necessaraly. You can use a DL-06 as a slave. Same with Terminator.
From ADs site:
H0-PSCM - Profibus slave communication module.
You can now add a DL05 or DL06 PLC sub-system to a Profibus controller network.
The H0-PSCM module allows the DL05 or DL06 PLC sub-system to be linked with a Profibus master controller. Profibus is a control bus that provides a common method to connect automation equipment with devices on a single network and significantly reduces hardwiring costs. Profibus provides specifications for information exchanged between nodes, such as controller data associated with low level device and configuration parameters that are individually related to system operations. The H0-PSCM module transfers blocks of I/O or register memory data between a Profibus master and a DL05 or DL06 PLC. The user can choose up to four blocks of data to be transferred. The data blocks can range in size from 1 byte to 32 words (64 bytes) and can be either input or output data. NOTE: Requires ERNI communications connectors listed in the DL05/ DL06 "Spare Parts and Accessories" section.
I stand corrected,
I have no problem with that because what I know about AD products you can write on the back of a postage stamp in block capitals and still leave room for the lords prayer.
So, one of the PLC's can be an AD, the other one will be a ...... :confused:
Paul
Paul,
The Master could be any PLC really. Heres a master converter: http://www.anybus.com/eng/products/abmoverview.asp
However, the question is why must it be profibus? He is looking for a MASTER & Slave. So if he goes with AD he could use the built in ports on a Master D0-260, and Slave D-06 with Modbus or DirectNet etc via RS-485, RS-232. OR he could go E-net.
P.S. I dont work for AD, I'm just REAL happy with them.
Actually Mark it cant be overstated. One of the attractions is the web site. It takes just a few seconds to order any job, and it's usually here within two days (ground shipping). Tech support is great, (very short wait), manuals are clear, and good quality products at a very fair price.
Just wish they sold phase monitors...
please help me . I have to make this ladder diagram and I can’t figure it out :(
395
80
Hello, I am trying to get a Yokogawa Hart pressure Transmitter and a Rosemount Temp Transmitter to read on a 1769-IF4 module on an L33ERM...
396
Please help me, I have solve many week but still not solve it. I found trouble of factory talk studio when I set tag by browse address of OPC...
128
Hello Everyone, i Have im my Industry a Endress & Hauser Promag400 this has a screen that constantly have that error, it says to wait, somebody...
499
