SandCoffin
Hi !
I search the forum however still not find the solution
My professor told me to communicate s7300 with kepserver, then do the same thing between visual C# and kepserver
I have done the latter thing, however i cannot communicate kepserver with s7300, i did follow the video on youtube but the tag connection in quick client still show "bad" status and unknown value
My configuration
+ channel : siemen TCP/IP ethernet, default ethernet driver
+ device: s7300, ID : 192.168.1.50 (also try to set the static IP the same value in properties of TCP/IPv4 but did not work)
+ tag : try these addresses I0.1, Q0.1, M and DB still did not work
My lap use window 8, connect to plc through COM cable with USB adapter ( dont know if it would be the cause ), have updated all the driver in device manager, no yellow mark
Thanks for reading my issue and appreciate any reply !
My configuration
