help to connect thermal printer with HMI serial port
Joe_1041
Aug 2016
Delhi
hi!
i am doing a project where . i have HMI with serial printer port. now manufacture cliam that any serial printer will work with HMI.
now on connecting thermal printer . it is not working at all.
pls. help if any one can....
You did not specify the HMI or printer models. Off hand I would check these manuals for the cable pinout to connect.
Regards,
It might be either the cable is/is-not a null modem cable, and you have to check the Baud, parity, stop bits, # of bits, etc for them to communicate with each other.
Any serial printer will use the same ASCII protocol but may have widely different comm's settings. And since there is no modem between the HMI and the printer it may need a null modem cable but some of the newer ones know of this and need a straight through cable.
I am going to daisy chain a couple Modbus devices off of a Click plc using rs 485. There will be three slave devices daisy chained off one another...
9,216
Hi group I had successfully established a connection earlier today but I goofed something up and have now been banging my head against a wall for...
2,554
hi, i try to connect sick clv490 barcode scanner to hyperterminal to send some command like "21" turn on laser beam. it work fine with sick...
1,493
hi to all i have a laptop Dell3521 with , windows 7 Sp1 ultimate , security kis16 i install step7 v5.5 sp1 and upgrade it to sp4 i can't connect...
1,807
Thank for your kind reply mickey... we are using MITSUBISHI FX5U-32MT/ES TYPE PLC.. we are in need to control the Permanent magnet dc motor...
2,147
