how to connect the relay to plc output side...help us
Nov 2016
india
Thank for your kind reply mickey...
we are using MITSUBISHI FX5U-32MT/ES TYPE PLC..
we are in need to control the Permanent magnet dc motor through DC contactor via interposing relay..
so we need to connect the relay to plc output port and then
the relay output is going to control the motor contactor...
could you help me in this occasion...
Hello, my problem arised when connecting this 12v 2 relay module to the relay output of a Mitsubishi Fx3g PLC, i have gone through the manual...
9,278
I have a sensor which works by passing current through water. I mean it is simply naked wire in the water tank. I use 24VCD. Ground wire is at the...
3,919
Hi, I have a relay and i connected by accident a relay with the wires inverted to the PLC (DELTA). By this i mean the the wire from the PLC...
6,658
I'm looking at iRConnect for a customer of ours and testing it to see if its a worthwhile solution, but it appears to me that it requires an...
3,204
T
Hello Where can I get inexpensive Relays that directly mount on a DIN rail like...
5,195
