help..usb/ppi S7200 ,windows 7
Just saw this so I am a little late... but
You did not buy the cable from us but it looks like they are using the same chip set that we use (CH340) so when using W7 the drivers are built in and its just plug and play, you can also tell this as when the drivers are installed you will have a COM number (yours 7) if the drivers were not installed it would not have a COM number also it would have a yellow ! next to the device
I would also like to know what you found wrong or what were the correct settings
I do not understand what you want ?
Is that what you want ?
Hello,
I don't see anything different... in your posting you say that it took two days but you got it working correct? if yes then what were your settings that you had issues with
Other then the node address everything looks the same
Best regards
Mark
I board had alot of trouble to install drivers
(CD).
the basic configuration was not good (changed)
Thanks for the information... the reason I asked was to help others that may have the same issue that you did
Best regards
Mark
Hello,I have a problem and who can help me ?It's urgent. Thanks all! I have a USB/MPI cable and everthing is OK,I setup sofrware and connect...
3,538
Hi Guys i have to get the datalog off the rsv project on to a usb every week, is there a way i could config a button to copy the files straight to...
1,385
Hey, thanks for a great side. My question is: " is it possible to use the USB simatic pc adapter to, directly communicate with a dp enabled...
3,239
Both hardware and software have be running on this PC. But I had to format my hard drive for other reasons so am re-installing right now and im...
5,140
I know.....the topic that wouldn't die. lol Has anyone been able to use the "no serial port" laptops with a USB com port to program the Allen...
5,098
