Help-AB SLC 5/04(RS232) to no serial port laptop USB ?
mjcandlec
Sep 2007
The Great Northwest
18
I know.....the topic that wouldn't die. lol
Has anyone been able to use the "no serial port" laptops with a USB com port to program the Allen Bradley SLC 5/04 via DF1(RS232)?
Please reply with the USB adapter you tried and results.
Thanks.
Thanks.
Yes. Both of the below USB to Serial converters work.
http://www.aten.com/products/productItem.php?pcid=2005010513171002&psid=20070130144911002&pid=2005022316346005&layerid=subClass7
http://www.keyspan.com/products/usa19hs/homepage.spml
I'm a big fan of the Keyspan 19HS product. Works properly with DF1 autoconfig, and has a nifty data monitor utility included. Works effortlessly with Modscan32, too.
Only the A-B 1747-UIC works for DH485 protocol. Trust me.
Thanks much for the replies.
I purchased a Belkin from Staples for 32.95 (needed to find one fast and took a chance)and it worked perfect for the SLC 5/04 and the PV550. Autoconfigured and communicated first try. It actually worked better than the old IBM laptop with the real serial port.
Machine has existing DN devices that are connected to SLC 5/04. All communication is working fine now. Supplier wants to remove some DN devices...
843
Hello everyone, I am migrating a program from STL to SCL via S7-1200 portal, I would like you to help me by converting these lines of code...
1,637
Hello Everyone, I'm a pretty green PLC tech and I need help logging on to some SLC 5/04 PLCs. I have a 1747-UIC and 1747-CP3 cables and I'm using...
6,961
Hello, I have a SLC 5/04 processor that I can't get online with and hope someone can help me with any ideas. This processor has a DH+ and DH-485...
3,256
I've got a guy looking for help with a SLC 5/02 with a flashing fault light near Charlottesville VA. It will be a while before I can get to it...
1,354
