Peter Nachtwey
The equation is a square root function
The obvious thing is to try a polynomial. If there are enough terms the polynomial will be accurate enough. However there is a give away, asterof said the pressure drop was across an orifice and the equation for fluid flow through an orifice is:
Flow=K*sqrt(DeltaPressure)
This makes find K easy as the data is almost too perfect. It looks like
Flow=2600*sqrt(DeltaPressure)
Simple, no AOI or look up function is necessary.
