Help with harware selection
Taliesin
Oct 2005
Wales
:book:Hi all, Been a lurker for a long time, now I need some advice if that's ok.
I have been asked to build a machine, and although it is a very simple machine im wary of how to start because I cannot decide which way to go .
The machine will pull from a reel a length of film, say 200mm. Now, it will do this everytime the upstream machine gives it a signal,(in the order .25HZ). Now it would be simple to program a pulse generator in the plc to give x amount of pulses on one of the high speed outputs. I could wire that into the stepper motor driver card and it would work very well.
The problem is the I need to change the length of film depending on the batch. so I will need a HMI and a way of making a variable change the pulses, (I don't know how to do that but I assume it can be done )
This is not the only way of doing this, I could obviously use a dc motor and an encoder and just stop the motor when enough film has been fed.
and then there is the question of PLC+HMI hybrid all in one units, and also there are stepper motors that have the driver , and controller built in!
there is so much option these days im getting swamped with too much info.
How would you do it, and why ?
Hope that isn't too much of an open question.
Thanks in advance for any help which comes my way..
Gareth
My instinct is to use a stepper or servo motor with an integrated amplifier that has enough control capability to use a tiny HMI or discrete inputs to change the index distance.
I do reel feed applications with Animatics SmartMotors. They are well supported in the US but I don't know about the UK.
Another good integrated controller/motor is JVL. They have a little "SMC75" controller board with a "nanoPLC" that could take Modbus over a serial interface or use discrete I/O from something like a thumbwheel to select the distances you need to run.
Schnieder MDrive steppers with their little embedded controller might also fit the bill.
If you are doing motion have a look at the Omron NJ - it is designed as a machine controller and uses EtherCat to the drives and I/O devices. Really fast from what I have seen. They have motors and controllers too.
Have not tried these as I do not do this type of machine control but a few friends do and they swear by it.
Some servo cards have pre-configured set points. All your PLC or controller would need to do is send the program number in binary or Bus enabled fashion. If accuracy is important use a servo. Otherwise use a Vector VFD with encoder mounted motor Or a stepper these you would have to use PWM. Some Vector VFD's also have pre-programmed steps.
Other option would be a linear drive from Festo with a gripper system. So many options but you need to weigh up accuracy vs.cost.
Hello, I am using the Unity Pro APIs to download application from PC to PLC. I need to know any API that can let me know any unique...
1,042
I've made a program for a 313C CPU with STEP7 LITE V3.0 SP2 and downloaded it to the PLC/Everything looks fine except the sad fact that I can't...
27
14,845
Hello, I am working with cimplicity workbench, I have made changes to the current project from this machine I am using in the past. However when...
18
Hello, doing switch from FBD to ST. First task is converting my old work. How do you sum variables? For example, Interlock1, interlocl2 and...
141
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
52
