I've made a program for a 313C CPU with STEP7 LITE V3.0 SP2 and downloaded it to the PLC/Everything looks fine except the sad fact that I can't see any outputs and even the inputs are active on the PLC itself got 24v signal but in the program itself when I try to monitor it it will come up on the Monitor/Modify table as Bolean FALSE.Even though I can see the light on input let's say I0.1 is on.The same story with the outputs.I tried to toggle M bits in the program and brought up a few outputs but they are not giving any 24v out neither their indicator green comes up.In the step7 lite interface I have everything ok except that I have a missmatch between the online hardware and offline hardware config.A red circle comes on top of the green square just beside the hardware icon.Which is fair enough as when I configured the CPU type I couldn't find in the list of CPU's the one I have in the PLC cabinet.Namely I have a CPU 313C With DI24/DO16,AI5/AO2,COUNT but the one I have in the cabinet is a CPU 313C with DI8/DO16,AI5/AO2,COUNT. So the differenec is that DI8 and DI24 .Because on the hardware configuration under CPU tab I have 313C with DI24 instead of DI8 and I have no ideea how to update that library in the software I think I have a massive problem unless I get something wrong.Or maybe the PLC should work even if there is a slight missmatch in the hardware config??
Please help me out as I totally stopped with my project and have no ideea what to do.
Thanx
P.S. Perhaps STEP7 Lite is not meant to be used with the processor I have (Unfortunately I don't have the exact numbers written on the CPU) but looking through the progarmming interface under details tab on the hardware config window this is the only difference between the two.
Thanx
