Help with IDEC WindLDR RDX2 routine
izula
Mar 2008
ABQ
Hi all. This is my first post. I'm looking for some help with the correct use of the latest WindLDR 5.3 RDX2 routine on an FC4A-C24R.
I'm trying to read a serial signal from a data logger that looks like this "TEST:0.0,1.0$$". The "TEST:" is the header, the "$$" is the tail. The serial signal goes out with a 9600 Baud Rate, and the delimiter is a ",".
I'd like to play with a test routine to drive PLC relays using the logic 1s and 0s sent out from the data logger, and build from there once I get the RDX2 routine to work. Thanks!
Rob
Hi all, i need urgent help with the programming of this PLC ( idec micro1 ) using windldr software package. My problem is that there doesn't seem...
5,167
I'm trying to figure out how to count up and count down via IDEC Smart Relays which i'm learning are the same as Siemans LOGO I1 Resident entrance...
1,550
Newbie question here, I have been trying to setup a Ethernet/IP network consisting of 3 AB Micrologix 1400 plc's, one Idec HG4G-CJT22MF-B OI, and...
3,335
hi my name is kyle i just acquired an idec micro 1 plc for free. i know it is way old and out of date but i took it for testing purposes and...
2,558
Joe here from Palm Gaming- hoping to find some help here- we run a custom made heat press- we make ***** chips for casinos- the press has the orig...
7,333
