Help With Read/write Error
gsajja
Jun 2005
Hi guys,
Iam trying to introduce numeric entry code to input the data into the plc. But it gives the write fail error to the tag address in mentioned in panel view. I have the same tag as controller.
Need ur thoughts
check application settings and connection.
make sure that node type is correct and
make sure the tag is using same node name as set in application settings
i have
Address
enter_number SINT NODE_1 machine1.enter_number
Iam using same set of tags for two machines i.e. if it is machine2 then it will have tag address as machine2.enter_number.
I entered all these tags as user defined tags in rslogix.
But gives me read error for tag address when I try to do numeric entry..
Need help
I just check a numeric entry on my PV600 and I use unsigned integer writing to an N7:XX
Ron u are right ,,, the PLC takes inputs in INT... I was trying with SINT ... thats giving me error ,.
thanks guys for all ur inputs ,,,
I am trying to get a floating point value into a CX8090 via modbus. The value is being read, but I cannot seem to get it to convert correctly...
2,616
Please help me get this file ?. Thanks you so much.
2,391
The PLC2 passed on, and I was jubilant to find files on a floppy. But now I can't find any way to read them... I have RSLogix500, if they could...
22
4,929
Hello forum members. I was hoping if you guys can help me understand why this CIP instruction is error out with this code 16#000C.
1,470
