help with rslogix 500 and excel
stu
Aug 2005
England
785
hi guys
i have a slc 505 running a flour system , and what i would like to to is record a number of readings to an excel sheet so i can see if we are getting the same amount of flour in every mix? this is only to help me fault find, is there a way i could do this, thanks stu
Yes. One way is to use RSLinx and make a DDE link between the processor and Excel. You will need anything but RSLinx Lite to do this though.
I have got it working but it over writes the last figure ,is the anyway I could use it as a data log for a period of time ? Thanks stu
Can you give me an example as I haven't done much vb , if I set up the data monitor paste link in rslinx,
For example F16.6 value how can I set up the vB? Thanks stu
The best way I've found for this is to write VB code in Excel to move the value and insert a new row for the new value.
Can someone explain to me how to do this , is there a youtube video or a step by step thanks stu
Can someone explain to me the purpose of this IOM instruction? N10:8 is fed from a PID and as you can see, when the PID Control bit is enabled...
1,418
So I used the migration tool for converting RSlogix 500 to Studio 5000 and the resulting came out. See attached png files. I am having trouble...
3,712
Hi guru's I'm after you help , I'm looking to capture data changes on a Hmi (pvp) I would like to know the best way to tackle this ? I would like...
2,363
Hello all I have a file that I’m having issues opening. It’s off an old machine and I don’t have rslogix 500. I only have 5000. Can someone please...
1,770
Hi guys I have a machine that works fine, but today we had an issue where the operator speeds the line up to 20cpm the feeder but didnt adjust...
3,209
