Rslogix 500 and Hmi help
stu
Aug 2005
England
783
Hi guru's
I'm after you help , I'm looking to capture data changes on a Hmi (pvp) I would like to know the best way to tackle this ?
I would like to capture any change to a recipe and time stamp and display on a Hmi screen(or a file)
In our recipe we have
Water
Flour
mixing timer 1
mixing timer 2
mixing timer 3
Oil 1
Oil 2
Oil 3
And if any of the info is changed I would like to capture what the change was and time/data?
Can you give me any ideas on how to create this please
I'm using a micrologix 1400 +pvp 700 Version 7
Thanks stu
There is the 'ME CSV Log' and 'ME Data Stor Plus' Active X controls you could possibly use. You can get the manuals for those on the Rockwell support site.
I seem to remember someone using the Recipe control so when you hit save it creates a new recipe where the recipe name is the date and time.
Is this the common way to do this or is there any other ways?
Do u have to use any code like gsv or fifo
Thanks stu
you could use micrologix datalog to log changes. if a change is made just send the data to a data log this will save all changes of all data that you chose. the file is called datalog.exe
You could do it either in the PLC or in the HMI. Since you're using Logix 500, I'd be strongly leaning toward doing it in the HMI, simply because storing all that data in the SLC-type data tables is time consuming and unnecessarily complex. If you were using Logix 5000, you could set up a UDT or AOI and have it done relatively simply, but not so much in Logix 500.
To be honest I'd probably lean toward doing it in the HMI anyway; in my mind this task belongs on a HMI/SCADA system more than it belongs in a PLC.
The DataStorePlus ActiveX is the way to go. Here's a thread where I worked through the process of setting it up with a Logix 5000 controller, but you should be able to translate it to a Logix 500 controller reasonably well.
I need to download a program to a micrologix 1400. Once I download it, the operator puts in some setpoint values, I need to save them to the tags...
2,698
Hi everyone. For my work area i am trying to set up two comouters. First computer runs ignition hmi The second one runs rslinx, rslogix and...
3,858
Hello, I tried to run advancedHMI with RSLogix 500. But it didn't worked. I watched the video of Archie on youtube and another one here...
3,057
I am having an issue with Rslogix retaining a bit value when the Red Lion goes offline due to a power failure. The setup is for a remote...
5,915
Hi everyone, so I am training at home without hardware, and Im using rslogix 500, with emulator it all works fine, my question is, are there any...
19
15,885
