Help with RSLogix 500 File
shawnhimself
Oct 2006
LBC
84
My employer sent me an RSLogix 500 SLC Project File and on the laptop I have with me I only have RSLogix 5000 and the free version of RSLogix 500. Is there anyway I can convert the file or view it without actually having the 500 software right now?
Also I can send it to someone and if they could just save the rungs as a picture and send them back to me that would be helpful as well! Thanks in advance for any insight offered.
Shawn
I am not a pro at this, but I think that in your 5000 software under tools you can convert a SLC/PLC 5 to logix 5000. This should convert the SLC program to logix5000 format. You may then have an idea of what you are viewing.
Ken
I have previously tried that but for some reason I can't get it to work? From what I can gather, I need to have the file open in 500 and create an ASCII text file before I can convert it in 5000.
No, there's no more info needed. You need to contact the original programmer. Failing that, you'll have to prove ownership to AB for them to unlock it Beyond that we won't discuss breaking passwords.
Can someone explain to me the purpose of this IOM instruction? N10:8 is fed from a PID and as you can see, when the PID Control bit is enabled...
1,414
So I used the migration tool for converting RSlogix 500 to Studio 5000 and the resulting came out. See attached png files. I am having trouble...
3,706
Hi guru's I'm after you help , I'm looking to capture data changes on a Hmi (pvp) I would like to know the best way to tackle this ? I would like...
2,357
Hello all I have a file that I’m having issues opening. It’s off an old machine and I don’t have rslogix 500. I only have 5000. Can someone please...
1,768
Hi guys I have a machine that works fine, but today we had an issue where the operator speeds the line up to 20cpm the feeder but didnt adjust...
3,209
