Help with servo
vermaut
Oct 2010
belgie
21
First servo project.
How can i calculate the distance to pulses?
I use a sigma 5 servo motor
230 V Incremental encoder (13 bit)
Straight shaft with key and tap​
Without brake 0.159 Nm 50 W
3000r/min
And how can i calculate Acceleration en Deceleration?
Are there formulas to calculate it?
Regards.
Sure you can use SCL, that is what it is for.
Your application will dictate the numbers. Perhaps 585123 pulses = 1272 MM position of your device and 8192 pulses = 5 mm.
The manual explains it.
Normally the plc will send pulses to the servo motor drive.
Hello automation experts, I'm trying to learn about servo axis control in AB ControlLogix PLCs (L33ERMS). Attached is an example of a servo...
1,085
Currently tinkering with a home project for a wood router lift machine using some second hand parts from a redundant timber mill. The servo is a...
2,450
Our Allen Bradley Ultra Series 200 Digital Servo Drive has been faulting out without providing a fault signal. After about 15 minuets of...
2,099
Hey All. I'm doing a little project at home where I have a need to automate something. I have never played much with servo or stepper technology...
4,391
Hi everybody I am using a servo which model is MR-J3-10B (GA). Now I have an alarm code 96(home position setting warning). How can i fix it?Please...
1,576
