bernie_carlton
In the majority of PLCs the internal processors are isolated electrically (usually by opto isolation) from the input and output circuits (I have seen some exceptions in some analog cards). This prevents damage to the internal processor if something bad happens on the input or output circuits. Thus there is no direct connection from the CPU power supply lines to the supply connections on the input and output modules, whether integral to the CPU chassis or as add on cards.
In your case you happen to be using the same power supply for the CPU and the input/output circuits. Thus you are having to make connections which seem to you to be superfluous. Believe me - they are not.
