Help with small Uni project in STL
nemosis
May 2016
Athens
Hi everyone. I'm new to PLC's and STL and i have a uni project i could use some help with. Here it goes:
There is a sensor where every time it counts to 5, a LED/output opens up for 3 secs, and then the counter resets, in order to do the whole thing over and over again.
I know it might sound really basic, but i've found very little documentation and none was provided from the teacher. Any help is appreciated :)
Here is the ladder execution of the program :
y9yrwfzo1
When you mention STL I presume you are talking about a Siemens PLC. Why you would do this simple task in STL is beyond me as LAD or FBD would be easier to read.
First I detect the rising edge of the input with FP.
Then every time the a flank is detected increment a integer by 1.
Once the counter has reached 5 use SFB5(TP) or a timer(T) to set the output high for 3 seconds.
Depending on when you want to reset the counter do it when it reaches 5 or when the output is no longer high.
STL cheatsheet http://www.plcdev.com/s7_library_functions
S7 functions http://www.plcdev.com/files/plcdev/STL-cheat-sheet-by-category.pdf
Note: is this really a uni project? then insert quote "I don't want to live on this planet anymore"
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
339
Good Afternoon , This may be a different subject on this forum . I have been brainstorming a project with my hometown. Like many small and...
1,844
Hello all, I need help in a small plc program in Allen Bradley plc. Need to generate a 1 second pulse on every ON and OFF of a bit. Suppose for...
2,111
Dear sir. i have one Automation Direct hmi, if you have the CMORE Programming software,i will send you .eap file in email, can you please...
2,446
Hello Gents, I am currently using AB CompactLogix Processor L36 ERM (Mid Range Controller) in an application. One of the device on the network is...
5,530
