Help with unsolicited message communication problem with RSLinx
syu
Aug 2008
florida
Hello,
I am running RSLinx Classic OEM v2.53 on a Windows Server 2003 R2 Service Pack 2 PC. I have two CompactLogix PLCs programmed to send CIP messages every 10 seconds. I am using Ethernet devices driver in RSLinx to communicate with the two PLCs.
The issue I am seeing is when the two PLCs sends the messages I am unable to see the messages and see that there is no two connection established on port 44818 on the PC (using windows netstat -an command). I am looking for the two connection established on port 44818 because when I am able to see the messages from the two PLCs I see there is two connections established on port 44818 on the PC.
I have contacted Rockwell support and they have not provided any solution or anything. I would appreciate any help from this forum because this issue has been very frustrating.
thank you
Do me a favor, please! My problem: I use AB logix5562 with 1756ENBT in slot 1 to send unsolicited message with MSG instruction to OPC client...
3,632
Hello, I am new to plc and am trying to interface with a compactlogix 1769-L35E through ethernet which is sending unsolicited messages every two...
4,358
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
107
please help me . I have to make this ladder diagram and I can’t figure it out :(
343
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
222
