Hide Development Button InTouch
Ones_Zeros
Feb 2014
at work
367
Hey
I have several computers that has development license on them
I want to add security access to this development button, so from within Runtime anyone can't open Windowmaker, without properly logging on to do this.
Is there a clever way to add or hide the Development option from with InTouch?
I was able to use group policy to restrict WindowMaker from opening, but I would rather do this within InTouch if possible
Thanks,
Haven't done InTouch since 2007, but back in the day I created a small window and set it's position to cover the development button. I think I had to set the window's X position to a negative number. Then I used CTRL+SHIFT+C to close the window and CTRL+SHIFT+O to open the window.
is there a way I could write a batch file so that with Wonderware access level rights I could click a button to enable or disable WindowMaker?
Thanks,
What Tark suggests with covering the menu bar with a small blank window is how I've always done it. The Y window coordinate is the one that needs to be negative.
I just make that window execute a check on $AccessLevel every 1000ms while the window is showing. If $Accesslevel is greater than 9000 then i hide the window.
Of course you could do it with a button too. Just use a memory tag that you can toggle on and off instead of $Accesslevel
Ok...I think i may have it but i do have a problem.
The small window I created that is to hide the Development option while I'm in Runtime is not appearing in all my windows?
Here is my script:
IF $AccessLevel>9998
THEN
Hide "Development" ;
ENDIF;
*Development is my small Window name that I created
* Also configured the window as a "Popup" so it covered the development option
This hides the development option, administrator has access level 9999 assigned to it, but it doesn't cover all windows just the one
If i open a different window I still see the development option
How do I configure this window to stay up & covering the development option on all of my windows that are opened as i move to different windows?
Thanks,
Here is my script:
THEN
ENDIF;
Thanks,
Use an "on open" window script on all of your "replace" windows to show the pop-up.
not sure if i understand??
here is a pic of what i have:
So say I have 50 different Windows configured
I would have to configure a Window Script on each of these windows to show the pop-up window that i'm wanting to use to cover the development option?
do you care to show a example please, so I fully understand?
Thanks alot,
Thanks alot,
Yes. You need an "on show" script for every replace window, since opening a replace window inherently closes all other opened windows. So, you'll need to show the pop-up again after showing the replace window causes it to close.
Does this look right?
here is a pic
The window script for the Window named Test will show the
"Development" pop-up window "On Show" condition
So I will have to make this configuration for each Window I have?
I have this script as "While Showing" so I can disable the pop-up window "Development" , after logged in as Administrator:
THEN
ENDIF;
If this looks right, I guess the only other thing to do is hide the WindowMaker program in the Wonderware programs folder, so
someone just doest open Windowmaker
here is a pic
THEN
ENDIF;
I wouldn't run the script that checks access level continuously while the window is showing. You could run it as a "data change" script triggered by $AccessLevel instead, and then it will only execute when necessary.
Dear all how to hide file menu + toolbar panel in rslogic500? I've seen other people use shortcut keys to hide and unhide. But I forgot how to...
346
I'm working on a project that involves updating messages on a Linx printer via ControlLogix. I'm sending and receiving data via sockets and can...
2,118
I'm not sure if I've come across a bug or I'm missing something very simple but I can't seem to hide a button in FT View. There is a...
1,640
I'm using Rockwell Studio 5000 V32. Does anyone know how to hide the UDT name from the tag description when tag descriptions are displayed...
1,881
Every time we get visitors, boss man tells me to "Hide". During his donkey and pony show, he doesn't want the customers to see me beating on the...
40
13,003
