High speed input over profinet
rQx
Oct 2010
Trelleborg
1,051
I have a setup of one master s7-1200 - three slaves s7-1200
On each of the slaves there is a HSC on a motor for positioning. It generates around 300-400 pulses per second, can this be transfered over profinet with I-device. Or is it to slow? The distance between the master/slave is within 20m.
Can it be done if the slaves were to have a Siemens LOGO also?
I'm in the develop phase so I investigate what path to go
/Tim
It depends on what the application is.
I assume that you are transfering the count value from the HSC module, not the raw impulses.
I think you should be able to achieve a Profinet update time of 2ms without much problems. If that is fast enough is up to the application.
For very fast applications you may need Profinet IRT instead of 'just' Profinet RT. I dont think S7-1200 supports Profinet IRT.
To find out the actual update time of the values you need to take everything into account. Also the CPU update time of both Controller and I-Device PLCs, and the update rate of the HSC module.
I was thinking of the raw impulses, having the slaves work as decentralized I/Os. Maybe et200SP with high speed input module is better? I can also just have it hardwired to the master PLC, that may be a easier way of doing it
If the slave S7-1200 doesnt do anything autonomously, then they are just Profinet IM devices, only slightly more expensive than regular IM devices.
At up to 400 pulses per second, I would not go for reading the raw pulses in the PLC program. Also, are you using an encoder to generate the impulses ?
If so, encoders usually have A and B channels. These channels switch in a certain order to indicate the direction.
A dedicated counter card can be setup to connect to the A and B channels and automatically count up or down.
So I would go for a distributed ET200SP with counter module (not high speed inputs).
If you go for the high speed inputs:
At 400 impulses persond, and assuming symmetrical on and off periods (!), you need to sample the inputs every 1 ms. And that must be consistently. Otherwise you will skip impulses.
I think that is too much for an S7-1200.
Yes, but we only use one of the channels. The alignment is not "that" critical on the mm and we only count in one direction. The other direction is just to get back to home position. I will look into the counter card, or possibly manage the counting in the slave (if I go for the s7-1200), thanks alot for your time and help
Disclaimer: I know very little regarding PLCs but I did a quick search for "quadrature encoder to Profibus" and a module came up. Although it was shown as an option for a motor controller, it appeared to be capable of standalone operation. Aren't you dealing with 5v signal levels?
It was like 700+ bucks, mind.
Craig
S7-1200 only support Profibus by adding a CM1243-5 module. It gets complicated.
Also, there are no counter cards for the S7-1200.
I think a small S7-1510SP CPU plus one or more counter cards would be a better solution than trying to make a cludge with one or several S7-1200 PLCs.
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
125
Hi all I am going to read gaps between product by millmeter to accept or reject product, with RsLogix 5000, The problem is : when the speed...
1,420
Unitronics Samba plc I am working on a system that uses the High Speed input on a plc to calculate the rpm of a shaft. It is having issues with...
20
5,538
so, id like to pick up RPM of a shaft with a prox. 800hz prox, and a normal DC input on a ML1400 can scan at 1kHz (scan time dependent). so with...
26
6,575
Everyone, I have an application where I need to pump a varying weight(depending on recipe) into a tank. I can't use the load cells on the tank...
1,517
