Hi all
I am going to read gaps between product by millmeter to accept or reject product, with RsLogix 5000,
The problem is : when the speed become nearly above 150 p/min
Cpu is L1765-L2, input module 1756-IB32/B, requested Speed of product is 600p/minutes, length of the product is 125 mm , the gap is 50mm
Requested packet interval(RPI) = 0.2 ms and I active enable change of state off-on and on-off , off sensor out put
The process: sensor see the start and end gap and read the actual position of servo drive encoder (96768 pulse/revolution) after Subtract and DIV I have the result, I mention to there are a lot of math rung to have the result, this result compared with stander gap distance to reject product
see attacment
https://files.fm/u/z5fzm6f3c
B.R
see attacment
B.R
