High Temp HMI
Burch
Jun 2014
Michigan
54
Good Morning,
I have an application where the ambient temp will be above the standard 55°C rating of an HMI. Currently looking a 10" touch screen from AB. Will be communicating with a CLX via Ethernet.
Any suggestions?
Thanks!
Good Morning,
Any suggestions?
Thanks!
Are you saying that there are operators (it's a touch-screen !) working in an ambient temperature above 55 deg.C ???
How far above ?
edit : I see that BryanG has made the same observation....
I have had to design systems that have to be able to operate in high temperature environments because the conditions can exist outside of normal operations...operators would need the touchscreen when the temperature is lower, but the equipment has to be able to survive the higher temperature.
Hi i need to enter some values of temperature for Low-Low, Low, High and High-High temperature sensing. i need to set these values through HMI. if...
1,387
The objective: Reach about 10’ horizontally into a 1300F furnace, and pick up a 140lb rectangular container, then pull the container back out of...
1,871
A colleague of mine is building panels with physical relay logic and it's fairly labor intensive. Simple applications, maybe 10 relays. I...
4,111
Hello! I am trying to write Modbus TCP to a UDC2500. I keep getting exception code 3(Illegal value) with any register. I am writing from function...
1,806
Good Morning , I have a Oven Band Tracker that I would like to make improvements on. This Oven Band Tracker keeps track of the position of...
2,042
