Hi folks,
Has anyone succeded in using Stegmann Programming tool v3.2 for Hiperface encoders ?
I have an issue, after the software send FF 52 (broadcast to read name plate of connected encoder), it then uses address 27h instead of 40h and so fail with the next 3 queries. Encoder doesn't respond as the protocol specifications say (address - 52h - RS485 settings - encoder type - size of eeprom - options - checksum), hence the issue of using encoder type 27h for the address.
I then must send direct commands, making it very hard to manage data blocks (I must copy them to another empty matching encoder).
Does anyone has a fix or an older version to make it work with SRM50 encoders from 2001 to 2004 ?
