Hirschmann Problems
SIMON0591
Jun 2014
LONDON
I have just bought two Hirschmann MS20 and two MM2 - 2FXM3/2TX1 modules but I cannot get a fiber connection between the two.
I can connect them together using the Ethernet ports but cannot get anything through the fiber ports.
I believe it is all set up correctly......... Any suggestions would be much appreciated.
Any idea what that connection parameters are to integrate a Hirschmann RSB20 8 port switch into the I/O tree of Studio 5000? Have not been able to...
1,195
Hi All I have an Ethernet IP MCC application with the option of Hirschmann RS20 switches or Eaton/Cooper 2080E-T. I was wondering how your...
3,441
Hey guys, Has anyone had any luck / know if it's possible to use Citect to monitor status data and statistics from a hirschmann managed switch...
1,774
hi, We Setup 9 hirschmann MACH1000 switches in an optic ring topology. we have about 30 modicon, ABB and Siemens PLC's connected to this network...
1,754
I have a couple of dell servers and i am trying to use hivision to get opc data display on the FT scada client. I have imported all the required...
1,628
