HistData Panel Wizard
Ones_Zeros
Feb 2014
at work
367
I was needing to export some InTouch Historical data
and i was needing 180 days worth of data exported
When I open the HistData Panel Wizard and the option that says
"Number of Records to Write per CSV file" the max number in the
field that I can put in is 500
I can export this into 4 to 5 different CSV files to get the 180 days
of data but is there a way to export all this data into one CSV file at once?
thanks,
Ok thanks I will give that a try.
Currently I have a trend setup to
Tread 2 tags
But if I select 500 records
It don't return on the CSV file but approximately a months
Worth of data.
If I input 1 record
Would I get 180 days of data for both tags
On this trend?
Hi All, I have a problem to export HistData Trend to csv file. When i click "Save to file" button in historical trend window at Windowviewer, i...
4,429
i use in my program the object HistData Wizard ,and when i connect him he create new access name and when i activate the view run time it`s...
12,587
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
82
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
208
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
399
