Wonderware Intouch Histdata trend error message
epicnote
Feb 2011
Malaysia
45
Hi All,
I have a problem to export HistData Trend to csv file. When i click "Save to file" button in historical trend window at Windowviewer, i get the error message "START DATE item invalid". Can someone here help me on this issue
Thanks a lot
Have you solved any of the other problems you've posted about? It is considered good practice to say thank you if anyone has helped you solve your problem, as well as bring useful for anyone else reading the thread to know that the advice given may be useful.
Onto this matter. ..The tag associated with the histdata start date doesn't have a value in it which the histdata application recognises as a date. Can you post the script that is executed when you click the save to file button (I trust you know how to open windowmaker and find the script? )
i use in my program the object HistData Wizard ,and when i connect him he create new access name and when i activate the view run time it`s...
12,589
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
157
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
167
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
428
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
196
