Historian points not visible on client (Factory talk)
PainAmplifier
Jan 2012
Monterrey
Factory talk server client system, one server for FTview, one server for Historian SE server. On engineering station where is rslogix, FT studio etc... In FT view studio when I put trend with historian point and run window on FTstudio it works, but when I save window and open on a client machine, the point is not showing in trend, and actual value is ???. when i trie to put historian point in user trend directly on client machine, when i want t search for historian point it says?
Error: -2147220478, Unable to open a session on a server. [-10431]
Authentication method is disabled by current server policy
Server causing the problem: "name of the historian server"
CallStack
GeneralConnectServer
PITagSearch:Search
Anybody had this expirience?
Yes it is static IP scheme, where to check this, what is Host file. But probably this is OK, cause error massage showing me that the problem is on "name of the server" so client see somehow server computer.
You can google Windows host files for better explanation than I can give. Basically, it's a naming table that tie computer names to IP address. Usually, it's found in:
windows\system32\drivers\etc\hosts
you can edit the file with notepad then save it. There's no file extension.
It's been a while since I messed with RSView SE so I'm going on a hunch here.
Did you ever determine what was going on? I have this same issue. I had this a couple months ago I think, and FT Tech Support went in and changed some of the trusts to resolve this. I'm not sure exactly what they did though
While I resolved my other issue, I am having some trouble adding tags to the Historian. Right click on application in FTView Studio, Add...
4,714
I am currently trying to display a set of historian points in a trend on FactoryTalk SE. I have 7 historian points added. The weird thing is that...
8,680
Hi all, I have had zero experience with PLCs but have started to work on an unfinished project. The control stuff such as RSLogix 5000 and...
17
17,827
I noticed that the new FTHistorian 9 only uses the PI 2018 still, and is not updated to 2023 yet. I figured by now any new releases would have...
149
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
139
