CageFreeBMW
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is multiplying the PLC tag by 0.1 to get the correct number. Someone has already set up all the links in Historian to the PLC tags so I'm hoping there might be an easy fix.
Is there anyway to add an equation to modify the tag from the PLC in either Historian or VantagePoint?
If I have to, I can add a bunch of rungs/branches to the PLC to create tags with the calculations already done in the PLC. But that, and re-targeting all the Historian tags, will take a lot of work.
