hmi and plcsim
seee
Dec 2010
singapor
112
hello.
Is it possible to connect easy view hmi software
to plcsim in order to simulate both hmi and S7 plc program?
best regards.
thanks a lot for your reply.
but what should i do in easy view software?
(i do whatever you had told in the pdf file)
could you please give me an example?
thanks.
I don't know the easy view hmi software.
But in general there should be an option where you can configure the IP address of your plc, and for S7 rack and slot number.
Example:
Your PC where Plcsim and Nettoplcsim is running has the IP address 192.168.1.10.
Then you have to configure this IP in your hmi software. Both devices should be in the same subnet, for example 192.168.1.20.
First step is a simple ping test between both partners.
Just think of, your PC where Plcsim is running is your real plc.
hi everyone. i hope you guys are doing great. i am trying to built communication between aveva intouch hmi 2023 and tia portal v18. i dont have...
573
139
50
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
73
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics show not only blower...
101
