HMI computer..best practice
jdbrandt
Oct 2002
Pennsylvania
1,203
I'm getting ready to set up a number of Dell-type computers
for use as HMI terminals.
I'm wondering if anyone has any 'best practices' in this area.
Virus protection? (I'm guessing NO, since there's no internet
connection and way to update it.)
Disk set up.
User name(s).
Programs to delete.
Operating system features to enable/disable.
Remote access (RAS)
I usually strip out the virus protection on non-networked computers. After that remove all games and programs such as AOL or MSN. You also may want to set up a logon for the Administator password with full rights and one for the Operator with limited rights. Make sure that you also have a UPS to protect the computers.
No guarantee that someone will not bring a floppy, USB jump drive or CF card that contains virus...
I saw once that games were installed on PC based HMIs by operators during first production weekend...
The amount of junk manufactures put on computers now a days is staggering. It sure would be nice to order a computer with just the OS.
For stand alone computers (those running the HMI), I make sure I have all the OEM’s drivers, wipe the hard drive, and reinstall the OS. I like knowing that everything on that computer is there because I put it there.
For larger systems I like to run the HMI on a server using Terminal Services. This allows me to only have to administer one computer, the server. I tell the customer that they can do whatever they want with the operator’s computers. You can save a lot of money not only in the up front hardware cost, but also in the on going administration cost.
As far as your questions, it really depends on the customer and what kind of system they have. I store the HMI application in a separate directory, generally called SCADA. For user names I use the first letter of the first name and the entire last name like jDoe. As far as programs go I sit down with the customer and discuss what they do and don’t want on the computer, some don’t mind games on the computers others do.
I always disable CD / DVD drives + USB ports + floppy in the bios to make sure operators do not bring games and stuff on the computer.
Secure bios with PW.
Ragards
Antoine
I saw this situation: unknown "advanced operator", probably one young man, had resetted the BIOS. And, of course, had installed a lot of games. BIOS was protected with PW, administrator said. Locking in BIOS isn't a 100% guarantee against this kind of young men too. Only big angry boss behind the operator can serve as it. :nodi:
Password will not help, BIOS can be reset within seconds, Windows Administrator password reset can be done as well, so no protection here.
Only good production practices and discipline can help...
When you get the system running, back up the hard drive with Norton Ghost or similar program. Then you can start fresh when needed. Also handy when creating a bunch of like computers.
That's why it's good to buy a "decoy" computer...in other words, we usually have one or two computers with internet connections and a game or something on them....they end up not messing with the server computers and development computers or operator stations.
Also, What are your thoughts about using Norton Ghost to restore every thing anytime just in few minutes ?!
This will take care of every possible problem.
Resetting BIOS PW is easy if you can access the inside of the box ! This can be secured with a lock. I have one "critical" computer, it is located in a closed room, I use a FO modem to connect a screen and mouse in the operator room ( NO KEYBOARD)!
Norton GHOST works fine (we use it a lot) BUT it assumes you re install the backup on the exact same computer; this may NOT be the case in case of hardware failure of the computer !! So, always keep your istallation CD and source software !
Antoine.
... i forgot to mention:
After the last computer crash due to illegal games installation, I asked the manager of the plant a play station and a big television with DVD reader.
The answer was: no.
... poor me ...
Best practices would include using a domain.
Also, for Windows platforms, study up on, and get to seriously know, the applet "GPEDIT.MSC" (type that into the start|run box to browse around it).
Gpedit will allow you to completely lock down a system, based on accounts. Regular users should have no access to system configuration settings, all removable media access should be disallowed (CD/DVD, Floppy, USB Sticks). Also, regular users should have zero access to any network resources, especially the internet.
The group policy editor will let you control just about everything in windows, it is very powerful, but tough to get started working with.
Of course, you need to have a strong password administrator account.
I would like to temporarily install AdvancedHMI on the same computer as FactoryTalk View SE. I am waiting for another contractor to finish the FTV...
559
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
943
Hello, I have two HMI application that is referencing the same PLC, a remote and a local screen. I am using Studio 5000 Emulate to do...
2,751
Good Morning , I placed a FactoryTalk ME application on a thumb drive . I copied it and pasted it in C:\Documents and Settings\All...
8,218
Hi, guys, how’s going? We get one SIMOTION D435 machine. The communication between D435, PLC and HMI is built by Ethernet cable. (D435 IP...
4,912
