HMI download problem
TomTom
Oct 2009
The Hague
18
Hi all,
I'm having trouble downloading the hardware config data to a HMI.
Situation: An MPI-network with 1 PLC (S7-300) and 1 HMI (KTP600 PN). I set up a project in WinCC Flexible and integrated it with the STEP7-project. In SIMATIC Manager I see that my HMI is added under the name Device_1. Double click Configuration and hardware config opens. I set MPI-address to 4 and click PLC > download.
The error that follows is shown in the attached image. The instruction SIMATIC shows, to set "S7RTM is installed", are not clear to me: I can't find the specified tab or window.
(See attached image)
Question: Is there anyone out there that knows what I'm supposed to do? Or what I'm doing wrong?
Thanks in advance for your time and help.
Cheers, Tom
I think that you go about it the wrong way. You should not transfer to the panel from the Simatic Manager.
edit: Only HMI's that are "PC Stations" needs a HW download from Simatic Manager. That is why the Simatic Manager "thinks" you are attempting to download to a PC station.
Set the MPI address and other parameters on the panel itself. On a Windows CE panel, you would have to open the "transfer" applet in the Windows Control Panel. Not sure how it works with a KTP panel since it is linux based, but it should be similar. RTFM.
When that part is OK, and the panel is connected with a suitable cable (*), then from WinCC Flexible you can start a transfer.
*: If you are using a PC Adapter, serial or USB, then you MUST connect the adapter to the PLC via a Profibus connector with a PG socket, and the panel should be connected via this Profibus connector, a profibus cable and a similar profibus connector on the panel.
Good people of PLCs.net, I am currently working with an HMI that is advantech 1250H, that communicates with a 1769 Compact logix and Currently...
19
Hey guys, after numerous browsing on the internet I came here to discuss regarding my problem with WEINTEK HMI. I had a half-blank LCD from...
4,147
Hi all, I have a Siemens KTP400 HMI screen which I am trying to download to but TIA portal keeps throwing up the error: A Communication error...
2,711
Hi, I am having problem with connecting to pt700 HMI with TIA Portal v13 though profinet. I have no trouble to connect with cpu 317-2 through...
5,227
So here's the deal, we have a new machine that they were running a speed test on at work today. On the HMI, there are recipes that are "saved."...
2,084
