Siemens HMI download error
DLMUK
Jun 2013
Southampton
311
Hi all,
I have a Siemens KTP400 HMI screen which I am trying to download to but TIA portal keeps throwing up the error:
A Communication error (802081002CACFFFF) occured.
Has anybody seen this before? I can detect the device online, I can go online to it and see things like the IP address, but cannot change it. I have tried creating a blank project with just a start screen and get the same error.
I am connecting via ethernet directly into my laptop.
Cheers,
I've had plenty of times that it wouldn't download even though I could connect, and eventually I figure out what i had wrong in teh config (wrong IP range, duplicate IP address, wrong transfer type).
However, whenever I run into one of those long error codes, I just submit a hotline case and wait for them to call me back. Sometimes it's something easy and I just need to recompile again, usually its something a bit more arcane.
Hi, I am having problem with connecting to pt700 HMI with TIA Portal v13 though profinet. I have no trouble to connect with cpu 317-2 through...
5,227
Hi Folks, Some help badly needed Im new to the HMI programming world. Setup is a TP1900 Comfort HMI TIA Version 13 So I have a HMI project...
17
8,022
Buona sera, Ho dei problemi nell' interfacciare PLC S5 con HMI 2a Gen. Siemens (ad esempio KTP400) tramite IBH Link S5++. il mio obbiettivo è solo...
107
Hello colleagues, On a Siemens Multi panel (MP 377 12") of a machine (S7-300) at a customer's site, some parameters need to be changed that have...
320
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,465
