HMI for home project
andydaoust
Oct 2002
Alaska
56
Hi Everyone,
I'm building a glass kiln. It will be a multi-segment temperature controller. I'm using an SLC 500 5/04. I'll probably buy a 5/05 for ethernet. I don't need the Panelview software and hardware to interface with the PLC. I can use RS Logix. I would however, like to set up the home computor so my wife could enter a temperature profile and monitor the kiln from inside the house. I thought there might be an inexpensive HMI as compared to the Panel View setup. I searched for HMI; there were many hits. Maybe you could help me narrow my focus.
Thanks,
Andy
Check out www.kepsales.com...
http://www.kepsales.com/hmi-products.htm
If the SLC 5/05 is in your price range Infilink should be, too. You can use RSLinx as your OPC server, or the KEPWare server (supports AB Ethernet). You can even download free time-limited trials if you want to check it out.
Be aware: when you call for pricing, you might get me on the phone. Take that for what it's worth. I don't want to use this message board inappropriately.
AK
I've never done it but I've read that the 5/05 (latest OS models only) can contain a small web page which should allow you to enter and monitor values.
Some info is at:
http://www.ab.com/manuals/cp/1747-rn009a-en-p.pdf
SLC 5/05 processors with OS501, Series C, FRN 6 (or higher) include
not only the enhanced embedded web server (introduced in FRNC/5)
which allows viewing of not only module information, TCP/IP
configuration, and diagnostic information, but also the data table
memory map, data table monitor screen, and user-provided web
pages via Ethernet using a standard web browser.
Someone here might have a link with more info or experience.
nOrM
I like the idea of using Excel. Any hints on how to get started? How would the data get between the PC and PLC? I must have to set up some sort of server eh? I know how to write the basic PLC program. In fact I'm mostly done with the ladder. I don't know much about Excel as a datbase. I'll be going to Tasmania to ride my bicycle in March.
Thanks,
Andy
If your going to use excel you'll need an I/O server RSLInx will do fine as long as its not the lite version then for monitoring you'll just need to set up DDE links..
i.e
1. Setup a topic in RSlinxs DDE/OPC (menu)>> Topic configuration
2. Creat a topic linked to the revevent PLC
3. Then to get data into excel use a =RSlinx|Topicname!'Bit address'
e.g =RSlinx|Kiln!'B3/0' would return the state of bit B3/0 1 or 0
=RSlinx|Kiln!'N7/0' would return the value in N7:0
Hope that helps any problems leave a message I have a few examples I could mail you if required...
Jezz
^^^Yeah, what he said ;)
However, it sounds like you'd also need to poke data to the PLC from Excel. In the Rockwell knowledgebase do a search with RSLinx selected in the product family field and Excel entered as a keyword. There are tons of results, many giving VBA examples and sample excel spreadsheets of how to do this using OPC, DDE, asynch writes, tables, etc...
Sorry I have not replied sooner. I had to work. Thanks for the information. I have RSlinx lite. The information has helped me learn a lot more about PLC's however. The link to the knowledge base was very helpful.
Thanks again,
Andy
Hi, I'm looking for a HMI or just a display if I can't find a HMI. I will soon have a s7-1200 at home providing some information and control. I...
1,462
Has anyone ever used a HMI to automate their own or someone's residence? If so in what capacity? Why would you or wouldn't you recommend this?
18
7,466
135
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
48
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
72
