Hmi input field format problem
Some one
Jun 2020
Egypt
Hi guys
I have a system of mp277 key hmi, s7-300 plc
Hmi has damage, so I bought weintek hmi to replace it
I have the cpu program so I got the tags and every thing is good except the Input field for the address for example DB18. DBD54, if I put 2 I get 20000 in cpu through monitor mode I have tried to change the format to 32bit flot, 32bit unsigned, 32bit hex, 32bit BCD, with no luck,
Hope u fine
Some HMI's have a scaling factor, cannot remember about Siemens but I once had the same thing on a Beijers HMI, normally the scaling is not enabled, however, for some reason on the PC I used the development environment automatically set the scaling factor to 10.0 instead of 1, Only had it once but it is worth checking any other tabs on the field configuration.
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
265
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
101
Hi, Is there an easy way to limit the input tag by using min and max tags from the PLC? Thanks
1,274
Good day all, Im just wondering if there are any existing hmi system tags that i can use as a plc input tag to indicate that there is a triggered...
1,077
Hello, I was trying to make a HMI simulation and i found that my HMI can’t affect the inputs in RUN Mode. When i press the button in Stop mode i...
2,254
