HMI platform that can import CAD files
lesmar96
May 2017
PA
520
We have a request from a customer to import a .dwg of the mechanical drawing of their system into the HMI. The components, like the motors, would need to be multistate to indicate status and we would like if they could have click functions.
What HMI platform is capable of this? Or is it possible?
Our PLC is Codesys 3.5. and I am not interested in Rockwell hardware.
Let me know if you have any experience with this. Thanks!!
Usually you'd export the dwg to a bitmap or something like that to bring into the HMI. dwg is a proprietary format, so I doubt that there are any that support them natively.
I'd try to convert it to a svg file, then you should be able to use any html based system. You load the svg file into the DOM, and then you're able to modify each element with some javascript. I've done this with a MS visio file, and using the webserver of a Siemens S7-1200.
For Allen Bradley platform, without PLC, can I use an .ACD file to create a new HMI ? No physical plc and only have some PLC program. want to...
1,765
Has anyone deployed any SCADA or HMI applications running on Windows 10? If so, what are you thoughts and experiences? If not, is there a reason...
5,169
140
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
51
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
75
