HMI solution for PC running Windows CE 6.0
cstca
Mar 2005
Toronto
33
I'd like to have an HMI running on a PC with Windows CE 6.0 (or Windows Embedded Standard 2009). I checked with Rockwell and Siemens and even if the PVP is running on Windows CE, they don't sell just the runtime license to be installed on another hardware. The PC I'm looking to use is Advantech TREK series and I have a Control Logix PLC L72. Communication will be over Ethernet IP. Are there any options for this configuration?
Thanks.
CoS
Windows CE is not a general operating system like Windows XP/7, it is a target-specific operating system, where OEMs (like Siemens and Rockwell) customize the installation on to their panels, and you use their development software to transfer the project to their own target. You should check if Advantech has a development software for their TREK series devices, and if they have the Ethernet/IP driver for your controller.
The recommendation used to be Indusoft studio, it will run on CE (5 and up) and on WES2009 (which is XP SP2). They'll sell you development and runtime licenses.
Nowadays you could look at PanelExpress, which would run on WES2009 (not on x86 CE tho). Development is free (through the designer software) and the Runtime price is based on number of I/O tags in-use
http://www2.advantech.com/webop/
Both of those have Ethernet/IP drivers. Indusoft will have more options, the PE will be Tag based TCP CIP.
I support plants with small number of HMI each, mostly 2 or less HMIs per system. they all got different HMI package, some WW, some iFix, etc...
3,262
Hi Guys. A vendor is delivering a non GMP machine with a 1500 CPU and 4 panels. one TP1200 and 3 TP700. Im searching con/pros for according to...
2,090
Hi everyone fairly newbie PLC guy here, I made a previous post about asking this specifically in TwinCATs "Visualization", but I'm starting to...
4,751
Hi all, We usually use Red Lion HMIs in our projects. Then, in addition to the HMIs themselves, we use our phones or tablets to remotely access...
3,679
Hi y'all, I am looking for affordable and reliable PLC and HMI solution : PLC with real-time clock and multiple (>16) relay output, modbus...
17
10,370
