HMI to LCD TV w/o PLC
zerokewl
Jul 2003
in a apt
50
Need some help/advice, I am trying to use an HMI possible with a TV-out (VGA) option, so I can push some manually fed data from the HMI to a Large LCD TV screen on a Machine, mainly for visual management?
Whats the best route to take care? I am avoiding
going through a PLC, so basically what u see is what u get on the HMI? Cause I need the manual data entry.
Thanks ALL :)
Hey Zero
IfI understand you correctly,your HMI has a VGA out?Wouldnt that make it a panel PC?Maybe a model number would help.
This may not help, but would a scrolling display be cheaper?
Alternatively - and this is on my next job to do - use a plc to automatically collect the data and send it to the HMI.
OR I certainly know proface HMI's can be connected via ethernet to a pc. Then connect the vga output into the screen. This may be cheaper than a panel pc?
Thanks for the replies, unfortunately the HMI (Arista PC) I am using has a max resolution of only 800x600,
therefore putting a large LCD screen, would stretch the display, I like the idea of using a PLC to just extract data, it would have to be traditionally done, wire by wire, since I am going from a Siemens S5 AS511 protocol
to ...whatever! I thought about having a PC for each dedicated LCD screen, and they figure out how to get data to the PC
from the Siemens S5 (eeessshhh), maybe a Redlion DataPlus unit? Has anyone used that?
You could always use a TTL card and send the data that way.
I am also looking for a cheap way to get data out of a AB PLC5 and Control logix processors and display on a large screen monitor or TV. At one time there was a spread sheet program that was out there but I have not been able to find it. Would probably need RS Linx lite or something to get in.
Looking for feedback on large LCD TV's to be used as HMI displays out on the factory floor. Wandering how they have held up in the summer heat...
3,059
Has anybody ever used a LCD or Plasma TV for an Andon Scoreboard? I have stalled out on search terms. I can find a bunch of the LED type. I have 5...
8,338
143
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
55
Does anyone happen to know how to install the graphic picture in HMI when I go into blower selection there are no graphics shown not only blower...
77
