Large LCD TV's as HMI on Factory Floor - Reliability?
plc_va
Jan 2008
VA
18
Looking for feedback on large LCD TV's to be used as HMI displays out on the factory floor. Wandering how they have held up in the summer heat and/or colod winters?
We have 3 of them on the floor for the forklift drivers and 1 in the drd for the camera inspection unit some of them are at 3 years with no problems
We have about a dozen 55" Samsung LCD's spread out over the production floor for displaying production data. They are suspended about 15' off of the floor, so they can't be monkeyed around with (or have an Xbox plugged in to them!). So far, after about two years, no problems. Sorry, I don't have the model # handy, wasn't involved in that project.
I would recommend Samsung - preferably series 6 (or 7 if you can afford them). Series 7 is as light as a feather - I have mine hanging on a piece of wire on the wall.
Ive got one next to a 3 layer extruder running a wincc application. Its hot and the screen vents have been covered in **** for two years and its still going. Its a 21 inch toshiba. Not as big as bobb's?
I know with larger motors you do not want them to start with a contactor above 30HP or so because they will 'sag' the power in the plant and the...
832
Hello, I'm digging all over the internet to find a solution for this but haven't come up with anything yet. We have 3 nearly identical machines...
972
Hi All, On my site, the standard template for storing recipes in the PLC is to create a tag called PartRecipe which is an 2D array - for example...
1,483
We have a panel with a 125HP VFD. We need to run #3/0 wire from the disconnect to the VFD & line reactor. The normal stuff is hard to bend and...
2,812
Working on an upgrade project, going to replace an L63 revision 17 with an L74 revision 30. In newer L74, MSGs with large tags as source/target...
776
