HMI Touch Screen for Beckhoff Embedded PC
coa
Jun 2004
96
What's HMI Touch Screen which you prefer to be used with Beckhoff Embedded PC (CX5000, CX1x00)? I'm mostly use Beijer HMI with Beckhoff ADS driver but we need to mapping variable to %MW address which is not flexible for us because we prefer to connected directly to Global Variable especially with structure data type.
:unsure:
Any Windows 7 PC running AdvancedHMI will let you access any variables directly by name. The global variables are accessed by preceding the name with a period.
I have used indusoft IWS. If your beckhoff controller has a DVI port, any DVI monitor can be used and put indusoft Runtime right on the beckhoff controller. I use Beckhoff monitors with touch. Instead touch screen, you can connect a mouse and keyboard to the USB ports.
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,467
A clients outdoor requirement is for a HMI to be mounted in an all weather (mainly heavy monsoon) enclosure. The touch elements on the HMI, should...
23
6,946
Hi guys, I have Siemens TP170A with touch non-operative. I have replacement but Touch Screen do not work (cannot set Transfer Mode to make a...
2,332
Good morning, Guys: we have one 15" touch screen HMI (model: YT15PC),we want to modify it,this HMI is done by a contractor, but we lost its...
3,529
I have a Proface HMI touch screen display model GP-4501TW. My problem is on the screen retention when the network communication via TCP is cut. I...
2,221
