HMI TP1200 missing tabs/features
Jethro Baidoo
Jun 2015
Accra
35
Good morning all.
I replaced a 315-2PN/DP CPU.
I downloaded the hardware config and the blocks.
After this exercise some HMI tabs are missing.
I didn’t do any work on the HMI.
A tab was showing tank level % but it’s no longer appearing.
How do I tackle this?
Unless some plc values change visible or non visible items ....
That’s a good one
Hello Jethro Baidoo:
What kind of communication is the HMI using for your PLC? Is it Simatic TCP client communication? Is it MPI? Or is it Ethernet ISO?
Do you have the sources of the HMI and the development tool of the HMI?
If not, did the developer of the HMI was kind enough to provide some diagnostics screen for communication issues? Do you know at least the tool with which this HMI was developed? I mean is it something like Intouch, Cimplicity, Ifix, etc?
Please clarify so I can further think about your problem. With the information you have provided, I can not provide more hints.
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
720
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
164
I've got TIA portal v18, KTP1200 HMI. I want to add a slider bar (if that's the correct name for it) to an HMI screen. Baslcally, like a...
1,125
I need to confirm that the can we convert the KTP1200 Basic PN to TP1200 Comfort HMI. I am using TIA Ver 14 and it shows the Device change option...
2,240
Hi guys! I've a TP1200 comfort panel that show me a white page with this problem: Update of operating system and reset to factory settings...
3,613
