Yes, there are a few tools for exacting stopping to target position. Usually motor have fit with el-mech. brake and it takes 100-200ms before it works.
Lower Min-spd gives better precision, stop-command cames when motor have allmost zero-spd, so Window-size can be smaller also.
I have done cart who max-spd is 3000 mm/s, 2500 kg mass with Laser location measure. Cart stops to same location from both direction, exacting is the same (1mm) than in Laser. It takes around 1,5 seconds from 3000 mm/s to zero.
br. Seppo
