Homework help, will pay
Danger
Jun 2009
LA
Well I need someone to help me with a PLC problem (Siemens
S7-300 series) . I'll be willing to pay by Paypal depending on how you help me and stuff. so post your msns here if you want to help
Do you want this quoted? Or is this a T&M job?
If the later know that I charge overtime after 5:00 pm and weekends.
Here's what he wants
OP said:
Design sequence sewage system control
Make your design for the sewage lift station on the following sequence of operation:​
All pumps OFF at the low level.
1st pump ON at the second high level.
1st & 2nd pumps ON at the third high level.
All pumps ON at the fourth high level.
Alarm signals shall be sent to the local control panel (light and audio) and to
the control room.​
When pumps are actuated they shell operate until the low level reached.
If one of the pumps is shutdown or switch off next pump shall be
automatically selected to operate​
The leading pump shall be alternated so that no pump shall have two
successive starts.
If you have questions, why not ask your specific questions!? We will HELP you with your homework, but we won't do it for you. Show us what you have, ask specific questions, show some initiative on your own FIRST.
See the link in my sig.
If you can't/won't do that, then you're on your own...
i have difficulty in the last part of the assignment
(The leading pump shall be alternated so that no pump shall have two
successive starts.)
The last part is referred to as "Lead-Lag" operation (not to be confused with Lead-Lag compensation in Control Theory). You see this to distribute use over two pumps, rather than have one doing all the work 24/7.
One pump is designated the lead, one the lag (think of it as a back up). The lead always turns on first. When both pumps turn on at the 3rd high level switch, the lead-lag designation is swapped, so that the pump that was formerly the "lag" pump becomes the "lead" and will start up when the level reaches the 2nd switch (after the pumps have turned off again).
The lag is also becomes the lead should the lead be turned off or faulted.
I had the exact same program that I wrote in PicoSoft, which was the first program I wrote out of school. No one explained to me how what "Lead Lag" was at the time and I didn't have old code to look at so I basically had figure it out myself.
It really is a simple program though, you can do it with a relatively small amount of code too.
HINT: Make the lead-lag indication toggle when the above events happen (make it a bit or something). I thought that was the tough part of the program.
It can get a little more confusing when a 3rd pump is added to the mix (known as lead/lag/standby)
successive starts.)
Show us what you already have? Perhaps we can see the problem and help you correct it...
I love turds, i will do the assignment for free :)
Danger: Pm me :) :)
Ill post the program so everyone can see :) Is it Ld, STL or SCL ?
I am tryin to create the subroutine that triggers by each second.DN but it's not moving my SQO. Is there anything wrong with my instruction?
4,330
So ive chosen the first option. Is it correct? it would be helpful If i could get an explanation too. thanks
2,281
So I have the following assignment for a class I am taking. "Program overview: The size of the load to be wash is selected first. The start...
2,578
Hi, Slightly off the PLC topic but i'm sure there are people on here with good experience... So I have no practical experience of control valves...
3,396
Hi, I have a question which is about picking the correct size value to regulate the flow of natural gas. I have been given certain values for...
2,044
